Hi all.
Help diagnosing my issue with my 2003 uZJ100 - petrol 4.7ltr V8 .
I was freeway driving at 110KM/H, listining to music, when I heard a ticking sound.
I reduced volume, realised it was coming from the engine, so I backed of, and it sounded like the car was low on oil.
I also noticed I seemed to be losing power.
So I immediately put it into neutral and rolled to a safe park, and stopped the engine.
I popped the bonnet, and what a mess.
The coolant had leaked out everywhere, the top of the radiator was blowing bubbles and hissing.
There was a large amount of oil, that looks like its coming from around cylinder number 4 ( looking at the front of the car, the left hand side, second one from the front).
This oil has come out with some force - blowing oil up and hitting the bonnet.
Once it had cooled down, I checked the oil level, and, while low, was still just above minimum.
The oil also looked as clean as it ever does.
I tried the engine for a few seconds, but it wouldn't fire.
The mechanic from the road side company that ended up towing me home said it sounded like the engine had no compression.
Obviously, a catastrophic coolant leak was the start of the matter, and I'm guessing, given the oil leak as well, from that location, I can only think that the coolant loss has caused the head gasket fail.
Is there anything else that anyone reading this could think it could be?
If so, I'd appreciate their input.
Assuming it is the head gasket, I guess I'll have to get the head tested for warping, weakness, etc., before replacing the gasket, but is there any other head related parts I should check, and/or service, prior to completing any repairs - such as valve clearance?
Thanks for any advice you can provide.
Josh
Josh
