Question for the 2UZ experts...
...I recently rebuilt my son's 2UZ-FE top end after a blown head gasket. After reassembly and fire-up, oil leaks arose from the front cover below each of the valve covers. I asked my local dealership's master tech about it and he inquired how I went about installing the camshaft oil seals, to which I replied that I tapped them in as per the FSM. He told me they don't do it that way due to seals being damaged when pressing them in. Instead they adopted the process of installing the seals along with the camshafts into the head and then clamping the bearing caps over them. Using that method they never damage the seals. UGH!
So I purchased another set of cam oil seals and disassembled all over again. After pulling the timing belt, camshaft timing pulleys, and timing belt plates, a couple of small puddles were visible on the flange of the forward bearing housing. That was reassuring, because prior to that I was questioning whether the leak could be coming from elsewhere!
Before proceeding further, I was wondering what the function is of the hole below each of the camshafts??? I poked a scribe inside to gauge how far in the went and it had me wondering whether oil could be making its way out through them. I could investigate where they lead to by pulling the camshafts out entirely, but I'd prefer not to loosen all the camshaft bearings just to satisfy my curiosity.
Thanks in advance for the answer.
-Marcel
-Marcel
