2nd gear start switch question?
Poulsbo, WA
I've noticed on 95+ landcruisers there is a 2 button switch to the lower right of the H-N-L transfer case lever. I thought one button said 2nd start and don't know what the other one is (manual/hold shift??)
Any way my question is what are the functions of the switch and would that work in a 94 landcruiser (even though there is no punch out hole for it)?
I tried searching, but its tough when you only have a slight idea what it is.
Thanks -Gary
BTW I'm learning so much about my new ride on here, that I might not need the owners manual I just ordered :) Thanks guys
The "2nd Start" switch starts the transmission in 2nd gear for better starts in icy conditions. This feature is not available on the older, primitive bus tranny in pre-95 80's (inside joke :) ). The other button is "PWR" (Power), which gives you slightly better acceleration by delaying the transmission shift points (allowing the engine to rev higher before shifting) and downshifting more readily. This feature is available on the 93-94 models, but it is activated by a button labeled "ECT" (electronically controlled transmission).
The 2nd start feature is particular to 95+ 80 series Cruisers with the 343 transmission. The other button is the ECT button (Electronicly Controled Transmission). You already have this button in your vehicle. It is in the instrument panel. The ECT changes the shift pattern. In the "normal" mode the transmission shifts, well, normally (imagine that :rolleyes: ) In the power mode the transmission holds the gears longer before up-shifting (except for wide-open-throttle) and the transmission down-shifts quicker on decelleration and kick-down.
The 2nd start feature bypasses 1st gear and causes the transmission to start out in second gear. This attribute is handy in very slipery conditions, such as starting out on ice, as it reduces the ammount of torque applied on take-off.
The vastly superior 442 "bus" transmission is not handicapped by this special "feature".......:flipoff2:
D-
Cool thanks. I guess since I got the truck I wanted with all the lockers, not having the 2nd start won't bother me. And yep I have the ECT button. On my 88 4runner I have one too. Came in handy when I had to tow a boat for a freind.
On a similar note.. the bulb in the ECT switch was burnt out and I replaced it with a 12V $1.50 one from radio shack (cheaper than $6 from toyota) But I was wondering is there supposed to be a dash light for the ECT power/normal mode like there is in my 4runner? (Because if there is I guess I"ll be pulling the dash and checking bulbs)
20Jan2005 (UTC -8)
alaskacruiser said:
This feature is not available on the older, primitive bus tranny in pre-95 80's (inside joke :) ). ...
Actually, US-spec 'Cruisers with the A440F (1990 to 1992) had the 2nd gear-start. Though it may not have had the button, putting it on 2nd gear makes it start from, well, 2nd gear.
When I press my 2nd start button I don't get any indication that it's on.
Is something supposed to light up? or is the button supposed to stay depressed. I'm assuming this works once you start after pressing the button and then it resets it self.
Yes. "2nd Start" should light up on the instrument cluster below the park/neutral/drive indicator lights between the speedo and tach.
You leave the button depressed as long as you want this feature to applied. As soon as you press it again, it turns it off.
:beer:
Rookie2
It must have been disconnected at some point by the PO or dealer. :mad:
I'll have to pull apart the center console and check if it's plugged in.
Should the "PWR" button light up as well? Mine stays depressed, but nothing lights up to let me know it's on.
Yep. There's a light for it too. It's either right about or right below the 2nd start light (I think above). Someone may have gotten in there and swap them out as spares for some other light.
Since I'm a newb at off roading I was wondering if the 2nd start ever comes into play while in the rocks? When in low range, after completing an obstacle and you have a short drive to the next obstacle, does anyone hit the button so your not revving so high for that distance, say 50-100 yards?
Buck
Buck
it's an automatic! set it to D...
I frequently use 2nd start when off road in low range. I avoids the very harsh 1 - 2 gear shift in low. It is necessary to remember to disable the 2nd start if you have to climb a very steep obstical from a stop. Even if it is just a 2 foot rock, if it is very steep, then starting in 2nd may require more torque than the engine has, especially given that I am usually packed heavy when offroad as I am usually carrying gear & supplies for a 5 - 7 day excursion. But on a reasonably level trail, 2nd start in low range works fine and saves beating up the driveline with the harsh 1 - 2 shift.
had not throught abpout the 1-2 shift thing, but I use it in low also, set the shifter to 2nd and the 2nd start on and the tranny just stays in 2nd gear no less no more. works well in flat but slow sections of trail/dirt road.
I find the 2nd start switch extremely useful in low range on the trail. I basically have it on the entire time when in low range. It makes driving between obstacles much smoother as you can simply downshift to first manually when getting into a crawling situation. Then on the flats you just shift back into 2nd gear and take off. I find the normal 1st to second automatic shift very annoying as you have to really push the engine to get the normal automatic upshift to 2nd and if you are in that 5-10mph range without the 2nd start button engaged the tranny will always want to shift back into 1st.
Does anyone know if you can install the 2nd start button into the 93-94 trucks? If the 91-92 trucks had it luck might dictate that the factory wiring loom in the 93-94 might actually have the connector hidden somewhere in the dash... maybe?
20Jan2005 (UTC -8)
Are you certain about that. My buddies 94 doesn't seem to behave that way. Maybe I'm mistaken though. I love that button on my 97 on the trail.
D-
My 95 has a 442 WITH 2start...it also has a 1HD-T
The 93 & 94 have the A442F which does not have 2nd start.
I have been thinking about the issue of 2nd (and even 3rd) gear starts for over a year and just came across this thread when searching. I have a '94 with the A442F and have a low range reduction gear in the transfer case. The 1-2 shift is really harsh in low and I have to really force the truck to make the shift by over accelerating and backing off the throttle, or it just wants to keep the rpms high in 1st. Great for crawling over obstacles, and certainly would not want it to shift mid crawl, but terrible for slow rolling down a rocky trail. I have to stop much more often than I like to shift in and out of high range between obstacles/steep climbs because I want to avoid this harsh shift on the drive line. This also holds up the flow of the caravan. In my buddy's manual Rubicon with similar gearing, I just start it out in 2nd or even 3rd gear on flatter parts of the trail in 4 low.
So I have really been thinking about tapping into the transmission control module and making some push button gear selectors for 4 low. Has anyone attempted this? When I bough the truck it had some bad shift solenoids and would start in 3rd gear quite often. So I should be able to cut power to the right combination of solenoids to select the gear I want to be in using a switch or 2 - picture a push button manual selector on an ashtray switch blank. When I do this, I am sure the OD light will flash because it will detect a problem with the trans. Perhaps it will stop flashing once I return the switches to bypass or perhaps I will need to reset the ECU/trans controller after each trail ride, which would be a PITA but I still think would be worth it.
Has anyone attempted to cut power to specific solenoids in order to make a "push button" gear selector? Would love to hear experiences with this. If not I am willing to be the first. I have the wiring diagrams and shift solenoid patterning from the FSM. I definitely don't want to cut any wires and it will take some time to pull the pins from the harness and make jumpers with proper pins to insert switching without permanently modifying the harness and connectors. I am willing to invest the time if there is a reasonable chance of success. Good excuse to do the Pin 7 mod for center diff lock while I am in there.
Thoughts? Just wishing me luck....??
