2nd Battery Ground to Block, where?
Discussion in '80-Series Tech' started by DRTDuck, Jul 21, 2005.
  1. DRTDuck
    DRTDuck
    624
    11
    Mar 28, 2003
    Boulder, CO
    Yes, I've read Christo's, George's, and other write-ups as well as searched and read the threads hear.
    I am ready to take the ground cable from my second battery to the block, but can't find a good spot. Most points on the USDS of the engine seem to close to the exahust. Is there a point down low I am missing.
    This seems like something easy to figure out. I guess I am just having a mental block.
    Please help with suggesting a good spot on the block, thank you.
  2. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    You mean USPS, right? Passenger side?
  3. clownmidget
    clownmidget
    2,430
    57
    Jul 2, 2003
    Trumansburg, New York
    I used the block ground point that is used for the ground from the firewall to the block just above the rear section of the exhaust manifold. It currently has a fiber heat shielded wire (maybe 12 ga) from the firewall to the block. I routed the ground wire from the aux battery along the top of the fender skirt, around the wiper fluid tank over to the block and used a slightly longer bolt to secure it. Its location is pictured here from George's site. This uses a bit more of the heavy gauge wire but was worth it to me to have it well away from the exhaust (in my case turbo). Hope this helps.
    it's the rear one holding the bracket...
  4. DRTDuck
    DRTDuck
    624
    11
    Mar 28, 2003
    Boulder, CO
    Yes, my typo, USPS.
  5. dfmorse
    dfmorse
    1,518
    2
    Jul 7, 2004
    EVERGREEN, CO, USA
    Doug;
    Not knowing how ur system looks; I'd just tie it into the negative side for the main battery, which is tied to the block on the left side. U can PM me for any other great ideas that I can come up with if U like. I've been rewiring my 80 & 40 for years now.
    See:
    http://homepage.mac.com/dfmorse/BattProj2/index.html
    dfm
  6. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    Here is where I put it, it is far enough from the exhaust.
    https://forum.ih8mud.com/showthread.php?t=35679
    If you want I can update the pics in that thread when I get back in a few days.
