2nd 80 Series triple locked
Discussion in '80-Series Tech' started by DR71, Oct 12, 2017.
  1. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    I decided I didn't want to mess up my '97 too much in the woods and found a one-owner, triple locked '94 in Atlanta with 300K that had just been posted and was, luckily for me, poorly worded about lockers. After reading the description on CL 10 times I realized what he was saying. Glove box is stuffed full of records, interior is good, only driver seat has a tear, clear coat is bad, but never wrecked, no dents and absolutely no rust. All I want to do to this one is lift it and put some Mud terrains on it. I drove to Atlanta yesterday to check it out and discovered the lockers will not engage (lights flash) and center diff and abs don't illuminate either. Needless to say he came down even further and I just couldn't say no given the overall condition. My question is : Could the problem be the switch on the T case? I have been reading up on what to look for, but ended up more confused. Any help would be great. Thanks
    MODist likes this.
  2. IanB
    IanB SILVER Star
    3,264
    1,043
    Jan 23, 2010
    Winnipeg, MB
    What's up with the Colorado plates on the front and Tennessee on the back?
  3. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    He bought it new in Colorado, lived in Knoxville, TN for several years then recently moved to Atlanta. In TN these tags are permanent so he never changed it.
  4. Malleus
    Malleus
    969
    Media:
    13
    Albums:
    3
    456
    Jan 5, 2017
    Charlotte, North Carolina
    I must be living wrong. I never get these deals :(
    Could be anything from dash switch to locker solenoid. I'd bet on the locker itself. Not expensive to fix, but you won't know until it's yours.
    EDIT: Sorry, I misunderstood your post. I'd test the solenoids first, since they're usually nasty inside and are a common failure point. Fairly easy to clean and return to reliable operation.
    DR71 likes this.
  5. incogrhino
    incogrhino
    584
    7
    Feb 29, 2004
    ravenna Mi sittin 10 deep.
    Keep playing with it.I got mine to work. Your in low right? Or do the cdl switch and 7 pin mod. Is easy and makes it easier to work with. I put mine up on 4 jackstands and used my boot to put drag on the one tire to lock it if it didn't grab right off the bat.
    BILT4ME and DR71 like this.
  6. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    Thanks. Will do, but what about the fact the central locker and ABS lights don't come on. Wouldn't that indicate the problem is likely further up the chain? T case switch?
  7. Rifleman
    Rifleman
    989
    520
    Feb 4, 2015
    I too own a 94, and had problems with my front and rear lockers not working when i bought it. Check the transfer case switch first, it's very common for them to get gummed up from non use. One other problem I'll point out on my truck. After i did the switch and got the rear locker working, my front locker would still not work. After taking everything apart to make sure the actuator wasn't full of rust, and testing it with a 9 volt battery per the FSM i found my problem. The wiring harness running down the front fender to the actuator had a short in it. After doing some reading I've found other 94's that had problems with that wiring harness too. So if you get everything else working, but not the front locker, and seeing as your truck is a 94, you might want to check that harness.
    DR71 likes this.
  8. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
  9. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    Thanks. The lockers were used only one time according to the PO, so lets hope it will be that simple. The harness is increasingly a likely problem from what I am reading. Going to start by bypassing the switch on the T case then checking the switch itself, then solenoids then harness.
    Malleus likes this.
  10. Malleus
    Malleus
    969
    Media:
    13
    Albums:
    3
    456
    Jan 5, 2017
    Yes, unless both bulbs were bad. I distrust bulbs for troubleshooting ;)
  11. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    I need my f%@!* head examined
    Great point. It is a 23 year old truck
  12. Malleus
    Malleus
    969
    Media:
    13
    Albums:
    3
    456
    Jan 5, 2017
    MY troubleshooting plan is similar to the FSM's, unless I know there's an easy, most-likely root cause: inspect at the end of the function chain and work my way backward. I only trust functionally operating components as correct; gears must mesh properly, solenoids have to move when energized, circuits must have continuity, etc.
    DR71 likes this.
  13. Lemhicruiser
    Lemhicruiser
    64
    3
    Aug 10, 2012
    Salmon, ID
    Pretty sure you have a VC on this year. Mine was bad and my cdl would not lock. If cdl does not lock neither will your front and rear. I chased my cdl locking problem for months before figuring out it was a bad VC.
  14. Malleus
    Malleus
    969
    Media:
    13
    Albums:
    3
    456
    Jan 5, 2017
    Yes there is a viscous coupler on the '94. Could be, but...
    How would you know if it was bad without testing everything else first? My first impulse would not be to pull the xmsn.
  15. Desert Dino
    Desert Dino
    334
    248
    Jul 5, 2017
    Israel
    The grill is of older model???
  16. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    No, thats a '94 grill on US models. Changed in 95 with the airbags if I am not mistaken
  17. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    Will know if its the T case switch shortly
  18. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    The switch was bad on the T Case. The front now engages but the rear does not, will figure it out this weekend, but the harness almost looks new. Ordered new birfs and Dobinson suspension today. Going to start clean up, running board and brush guard removal tonight. Thanks everybody for your help.
    David Otero and IanB like this.
  19. IanB
    IanB SILVER Star
    3,264
    1,043
    Jan 23, 2010
    Winnipeg, MB
    The rear is toothed more coarsely than the front, meaning it needs more differential rotation between the tires before it will engage. Try it in gear on jackstands and drag a shoe or something on one rear tire to slow it down and see if it will engage that way. Obviously be very careful doing this, probably best to have someone remain in the driver's seat and another helper apply some drag to one rear tire.
    DR71 likes this.
  20. DR71
    DR71
    82
    Media:
    1
    Albums:
    1
    73
    Jan 4, 2017
    Chattanooga, TN
    Update: Both lockers are working.
    Will do. Thanks!
    IanB likes this.
