Hi all, newbe here
In need of help w/2lte loosing power after approx. 40 kph when engine check light come on. The engine starts easy (-25C or +25C) no out of ordinary smoke, sounds normal. I have did diagnostic and it gives me a code 12, which accorting to all the reading and finding that I got it's the (Timer Control Valve). I've tested with ohm meter and I get a reading but I have no specs. I've also check wiring, connectors, got a new fuel filter on, took front end apart to make sure timming belt had not jump, replace injector pump from other complet engine that I have, except for the big hole in the block when the connecting rod #4 went through it, check Crank Position Sensor & even swap it with the one from other engine, swap Turbo, swap computer.
Now need help from other Land Cruiser owner that mabe encounter the same problem as I
