Hey guys, i have recently purchased a 1990 LJ78 SX5 prado and am working out a few problems it has. I have just replaced the priming pump and noticed that it does not have a air bleeder screw on it. How do i get all of the air out of the fuel lines? I have cracked all the injectors and turned the engine over until there was a constant stream of fuel comming out of each. It starts but only when i pump the priming pump 15 or so times. Then it will die if i dont keep pumping it. Should i start the engine and bleed the injectors 1 at a time? Any help would be greatly appreciated.
Thanks
Thanks
