GTSSportCoupe
2LTE abuser
You're obviously very well read and planned about your build. With that level of attention to detail, you should have a successful trip. Do you have a blog somewhere that you'll update as you travel? I look forward to hearing how you make out.
When the fans really crank up and draw lots of air the blades bend quite significantly toward the rad. 1/2 is probably fine, but is pretty close. Would suck to have interference when you're in the middle of nowhere. Something to keep a careful eye on especially if you switch to a different fan I suppose....
I have about 1/2 inch of clearance between the fan and radiator.
