Hi all, don't post much but am often on here gleaning free advise, thanks for all those times.
Patient: 1987 HJ60 I bought off another member, estimated 400,000 to 450,000 kms (he'd replaced the instrument cluster). turboglide turbo, 2 1/2" exhaust. I did a lot of work to the truck, and now have it on the road and run 4 tanks of fuel thru her, 600 kms to tank, steady 22 miles to the gallon. Thought she was using oil and took almost 3 litres last night.
Pulled off the turbo lines, oil evidence in all lines even turbo to throttle body. Considerable amount of blow by which would account for some. I need to do a compression test, but don't have a diesel tester yet.
On start up cold, large amount of oil spray out the exhaust onto the floor. Not carbon, but wet oil drips. On startup with cold engine, oil pressure goes up over 100 psi and burys the needle. On the highway, 80 psi, 30 psi at idle. I was on here last night and found out turbo oil seal is rated for 60 psi and relief valve may be a problem for me.
What's my best course of action here? Should I go straight for the relief valve? If so, where is it located and where would be a good source for replacement? Are they available in different pressure settings? I'm in Southern Ontario. Also .read something about catch cans, I take it these are for blowby? No apparent play in the turbo either
I intend to do a compression test as soon as I can. Motor runs fine, lots of power, rough on cold startups, but vibrates at idle which is why I was going to initially do a compression test initially. Expected more than 22 mpg as well, but may improve yet.
I'm a cummins guy with a first generation so the high mileage didn't bother me in a diesel. How many miles can these engines manage before needing rework?
Thanks for any advise guys!
