2H turbo'd. Rebuilt about 20,000mi ago, was not involved with the rebuild so don't know any specifics.
Ok 2H, and other, guru's. After reading all that I could find on here about smoke, I am still not any further along. I had the injectors tested/rebuilt. I did a compression check all where between 400-420psi. It seems to get more smokey every day that I drive it at start up. Now, after startup and the big smoke goes away you can still see a light white smoke at 1100rpm idle. I had noticed a slow reduction of coolant until the other day when I noticed a significant drip and looks like it is coming from the water pump. So, I don't think there is a gasket leak? I did try running with the radiator cap off to see if I could see any air bubbles, but the level was right at the top and when I started the engine the coolant level went over the fill so I stopped that test. Maybe need to try this again after trying to get the coolant level a little lower first.
So, any ideas? I can't really identify any smells from the exhaust, but definitely does not seem to be any diesel smell anymore since after getting the injectors rebuilt. There might be a slight oil smell maybe?
So the only option I can think of is to remove the head and have a look. Maybe replace all the valve stem oil seals?
Is there any good head gaskets to get? I can't find anything specific in all the kits out there about the head gasket material. I keep reading about a metal (MLS?) head gasket. Probably need a whole gasket set.
Thanks.
Thanks.
