2H oil recommendations....noob=me.
Calgary, Alberta
Hey all, thanks for all your help on my previous questions.
Again, I have performed a search and can find a lot of information but none that specifically answers my question.
How closely do you guys follow the oil bargraph in the owners manual?
My '86 HJ60 (2H engine) is very low on oil (I don't even want to drive it as is). But I have a bit of a dilemma on my hands, I don't know what the PO used for oil so in theory I cannot really top it up.
Living in Calgary I had pretty much decided I would run 5W40 synthetic during the winter to ease starting, what would you approximate to be the "maximum" ambient temperature at which I could run 5W40? Currently the average daily temp is 17C (63F), is this too warm? I am willing to let it sit on very hot days if need be.
I could just do a change for 15W40 but I put very few miles on it so it is likely to get very cold before I even get 1000kms on the change. In other words I am too cheap to fork out $100 for an oil change twice in two months.
More or less my question is: at what temperature should I be changing for my winter oil?
How are the numbers affected if I try 10W40 rather than 5W40?
Any information or experience you could provide would be appreciated.
Thanks.
I thought the 5W-40 can do the same job as the 15W-40 bith share the same top visco temp .. and how you determinate that your 2H it's running low in oil pressure . .?
hope not based on the factory dash gauge ..
Sorry, I should have clarified...I do not know if the oil pressure is low, it is just very low on the dipstick,
If its low on the dipstick just add oil. Oils (mineral or synthetic)mix fine now. Its more important you have oil in your engine than what brand or type it is.
My big question to you is why haven't you changed the oil? If you don't know what the PO used it is likely you don't know when the last oil change occured. Second, if you aren't driving it much, why would you spend the $ to put in synthetic. Put in a good mineral oil 10W40 like Delco 4000 and plug in your lower rad hose heater/block heater or garage her when it gets cold.
While you are at it, finish off the rest of the service and change all you oils (difs, T-case, Tranny), grease (unis & tierods) and change your coolant (flush first). Don't forget changing your air and fuel filter. Note down the kms, date, products used and then you will know when you need to do it again.
I run NAPA Fleet Pride 15W40 all year round.
Connecticut is not nearly as cold as Canada but I do drive to upstate NY near Montreal frequently and have not had starting issues even at -15 F to -20 F.
I would be concerned if the oil level is low. Most oils will mix without a problem, so topping up your oil is a priority and I would use whatever you have around if you are planning on doing an oil change soon.
Good to hear that mixing oil is not that bad.
I haven't changed the oil to date because I just purchased it in August and was waiting for the winter change. As for the low mileage you spoke of, I own many motorcycles so I try to avoid driving 4 wheel vehicles during the summer (except for hobby 4-wheeling). That being said, this is the only vehicle I have other than bikes meaning the amount of driving is going to go up in another month or so when the bikes get stored.
I have changed the T-case and Trans fluid, I do know according to the PO that there is fresh coolant in the system as he had just replaced the rad a month or two before I purchased it. It is Toyota Red and it looks good so far.
Thanks for the info.
Synthetic oil is the way to go, especially if you don't put many miles on. 5W40 will protect great in summer and winter (that's what it's designed for). I use it in my 87 HJ60 and my 84 Benz and have great results.
Go to a farm supply store (I forget what Alberta has but Ontario I go to TSC). They often have the cheapest diesel oil. I pay 19.99 for 3.78L. BTW, a 2H diesel holds 10L of oil, so a change is quite expensive on synthetic, but IMO it's worth it. And be sure to change the filter. Never trust the PO, or you will be P-O'd!!
2H is indirect injection and will soot up quickly. Its likely also an old engine with lots of kms on it. Your wasting your money dumping synthetic in it. It will still soot up just as quick as a good mineral oil will and have to be changed. Do it every 5,000 kms and you will have no worries. If you have extreme service than do it sooner.
I run cheep 15-40w mineral w/ a purolator filter year round and change it often in my '84 BJ 60.
Slight hijack - Do you guys have any thoughts on quality of Oil for a 2H? I've put in the Canadian Tire $33 for a 20 liter bucket for the last 2 changes. I like the idea of frequent changes with cheap oil, but worry about lack of additives (like Zddp or whatever that zinc additive is called) and wonder whether I should get something a little more expensive.
Any thoughts?
I try to take care of my engine as far as I can do ( and my wallet aford ) so I'm stick with Castrol, not the best, maybe not the cheapest ..
