Read the 2H shop manual and on page FU-42 it has an instruction to "turn the stop lever" and it shows a thumb on it. Do you suppose it is a manual stop in case the intake shutter diaphram or vsv fails and you can't stop your engine? Auto trans doesn't let you pop the clutch with brakes on for example.
Page FU-97 has 11. Check Stop Lever Operation, pump rpm 0, control rack position 2.0mm or less. Does that give it away?
I can't operate my engine as it isn't fully installed.
