Hi team Mud-
I've got a 2H that has been giving me cooling troubles lately. I'm not sure the issue is specific to a 2H yet, but thought I'd start here before asking more generally.
Some background: I rebuilt the head about 2000mi ago to fix some worn valves. Reassembled with new gaskets, everything torqued per FSM. I flushed and refilled the fluids, ran it around the city for a few weeks, and then did a ~1300mi trip with no problems.
Earlier this year I had to move houses so I put the vehicle in storage for a while, pulling it out in July to do a long weekend trip. On the outbound leg of that trip the engine overheated, with the stock gauge just touching the red. I stopped at an Autozone, cooled things off, topped up the coolant, and continued on my way. The engine stayed above operating temp but largely out of the red for the rest of the trip, although it kept needing to be topped up with coolant. On the way home, it started getting really hot any time we'd slow down - moving was fine but stopping at traffic lights would cause the temperature to rapidly increase.
From this behavior I assumed the cause was a bad fan clutch, but it still seems to spin fine. I've not worked up the balls to stick my hand in it yet, but I can't seem to get it to slow down like the youtube videos of bad fan clutches that don't take much of anything to cause them to stop spinning. If I turn it by hand with the engine off there's definitely the same amount of viscous resistance I always recall feeling.
I back-flushed the coolant system with a hose through the heater core until clear water was coming out everywhere. It doesn't seem like anything is blocked, but I'm not certain how to confirm that all passages are flowing.
Next I pulled and checked the thermostat. It opened fine in a pot of boiling water, but they're inexpensive to replace so I put a new one in. Running the vehicle with the thermostat out results in the coolant temp as being below operating temp as expected, unless it's really being pressed. Any time the new or old thermostat is in, the vehicle quickly overheats while operating under very low load.
While doing all of this, I noticed some bubbles at the radiator cap. I got a combustion gas tester, confirmed that it sees combustion gases at the tailpipe, and checked the radiator neck where I couldn't get it to register anything. There's definitely some sort of gas coming through the coolant system, but I can't tell if it's due to coolant boiling or a cracked head or head gasket leak. There's no sign of oil in the coolant or vice versa.
The coolant system is pressurizing well beyond what the radiator cap is rated to, causing the coolant reservoir to fill and overflow. After the engine cools, the coolant system never develops a vacuum to draw back from the reservoir - the system holds positive pressure more or less indefinitely after cooling. I assume this constant cycle of pushing coolant out generates a trapped air pocket that just gets worse, but any amount of topping things up doesn't seem to get rid of it.
The last thing I just checked was the water pump - I thought if it wasn't moving coolant effectively that'd explain the boiling over, as well as the significantly different behavior when the thermostat is in, as well as the inability to purge a trapped air pocket. I pulled the pump impeller and it seems clean - I replaced it a few years ago and it still looks effectively new. I don't really know how to check the specs of the water pump, all of the surfaces look like they're essentially where they should be, but I don't know how tight the tolerances are supposed to be.
I'm running out of things to diagnose here. The radiator is relatively new as well, and as far as I know there isn't a whole lot more to the 2H cooling system. Am I overlooking something obvious? Or do I have a cracked head or bad head gasket and it's just not pushing enough exhaust gas in to register in a hydrocarbon tester? I assume with a diesel, even a fairly small leak would cause the coolant to turn black like the oil does, but maybe it doesn't work like that. There was some sediment in the reservoir last time I drained it, should I try and get this tested somehow for hydrocarbons?
Thanks so much!
Thanks so much!
