can I use the passenger side motor mount from the 3fe for my 2fe? the 3fe seems beefier and has extra support to the head for the power steering pump. It looks like the 3 holes on the lower part will be fine but I might need some kind of spacer for the part that goes to the head because the 2f block is a little taller?
The 2FE uses the 2F block. Wouldn't it just be easier to use the 2F mount?
I have not had to think about this because I already have a 2F in my FJ60. I will just pull the head when the time comes and start bolting on all the EFI goodies.
I gotta agree with klinetime574. Using the stock 60 motor mount was a "no-brainer" for me, mostly because the swap provided plenty of other areas on which to use my somewhat limited brain resources.
The passenger side mount on the 60 also has an attachment point for the hardpipe that the lower radiator hose attaches to that I am not sure that the 3FE mount has.
