I had a 2FE conversion done in my FJ60. I then had to go on a 2500 mile road trip as my mom was dying. I noticed I did not have any interior heat during the drive. I will be driving back to Montana next week and I will need interior heat to defrost the windows. The mechanic that did the conversion hooked up the outlet at the top of the water pump going to the top of the heater valve on the bulkhead and the return from the splitter of the rear heater to the lower outlet on the water pump. Is that correct is is it backwards? I made sure that the heater valve works with the inside controller cable and there is coolant in that line. Thanks.
