2f won't run
stuart draft va
Hey guys I got a 2f that i redone had the cylinder head machined plus a valve job also desmogged it and finnaly getting it together and I bought a new 32/36 weber and now it will not run !? Any chance I adjusted the valves wrong ?!? It use to have 150 psi on each cylinder now I have 60 to 120 psi
There are two alignment marks on the flywheel: a TDC line and a ball bearing at 7*BTDC. The ball bearing should align with the little needle in the timing window at idle speed. Timing gun set at 0* advance because your 7* advance is already taken care of by the BB.
