dgangle said:Wanna little freindly 2F/V8 debate?
If you like, but there's really no debate.
Does your V8 rev out to 7500rpm?
bad_religion_au said:DOES YOUR 2F :shock:?
I am going to guess no...VTFJ40 said:Is this a stock 2f you spin to 7500RPM?
500lbs reduction with a v8??AspenFJ40 said:Really all depends on what you want to do with it. Compete with others off the start at red lights?? Go with V8. Better gas mileage? Probably also V8. (debatable, I know) But if you are offroading, the 2F gives great low end torque and is MUCH heavier over the front end. In fact, if you do a normal V8 swap, it lightens the overall weight by aprox. 500lbs!! That gives you an idea of the heft the 2F carries. There are also so many cooling issues reported with V8 conversions - IMHO, the FJ40 is made for the backroads, not necessarily a showy street rod.
My $.02
Kevin
77 FJ40 2F
