Hey Guys, need a little help. I'm running a rebuilt 2F with unknown performance cam with a TBI conversion. Using all sensor including VSS. I have a rough idle and have to advance the timing quite a bit so it won't backfire through the TBI. Other than the rough Idle and rich conditions it runs really awesome and has tons of power. I could just leave it be but I really want to find the issue. I've read through countless hours of TBI threads on all the TBI forums and I'm still dumbfounded. I'm running stock astro van chip and I know if I want perfection I need to have a chip tuned for my exact application. I was just thinking someone might have someone might have gone through this already and maybe has some knowledge they could pass along.
After checking fuel pressure, wiring, injectors, O2 sensors and all other sensors I might have narrowed it down to the MAP sensor. Although I'm only throwing the MAP isn't throwing a code I did notice that I'm only getting 12-14 hg vacuum which I've read is on the low side. Thinking the computer is dumping extra fuel giving me the rich conditions code 45. I'm going to try and use a vacuum pump and see if it changes when pressure to say 20hg's. IF it makes a difference then that just might be my problem.
There also seems to be a lot of different chips used in various years of the S10/Astro van with the auto trans. Can anyone tell me what stock chip number they have had success with? (Example ADUL) If I can't figure this out I'm going to bite the bullet and go with the dymamic EFI set up so I can adjust the chip on the fly but I have to learn how to use the software and figure out what all the tables mean. Thank you in advance for you help.
