For Sale 2F Parts All $5 Albuquerque, NM (3 Viewers)
Colorado
UPDATED!! PARTS ADDED
I am parting out the remainder of my 1977 2F. What is left can all be bought for a lump sum of $100. Before it was pulled the compressions were: 1) 128 2) 125 3) 115 4)128 5) 120 6) 125 The engine passed New Mexico smog. I take Paypal, and shipping isn't included for any of these parts.
Everything listed below is $5.
1. Radiator Lines (soft, but would use as spares)
2. Water Pump
3. Smog Pump (no longer working)
4. Front engine brackets -Sold
5. Rear Engine Brackets -Sold
6. T-Stat Housing -Sold
7. Bell Housing -Pending
8. Clutch
9. Pressure Plate
10. Air Rail -Sold
11. Valve Cover -Sold
12. Vac Line (soft lines, bought new from American Toyota) -Sold
13. Smog Switches (4) -Sold
14. Oil Pan -Sold
15. Air filter (with OEM filter) -Sold
16. Oil Sender -Pending
17. FJ60 Side Cover -Pending
18. FJ40 Side Cover
19. Starter Napa -Sold
20. Starter OEM (on its way out) -Pending
21. EGR
22. Other, let me know what you are looking for, but realize the engine is pretty stripped down.
23. Head and block is yours if you pick it up.
Other $5 parts.
24. 77 distributor/coil/ignitor (unsure on condition, replaced fuel pump at same time) -Sold
25. FJ60 PS pump, condition unknown it was given to me with my box, comes with bracket
26. Saginaw PS pump off a Volvo -Sold
27. Oil Dip stick
28. Ball Hitch (mounts using four holes on back bumper
29. Old gas tank, starting to rust, but could be resealed, (NO SHIPPING)
Not $5 parts.
77 FJ40 Brake Booster and Master Cylinder, have paper work on Master Cylinder from American Toyota, about one year old. Together $175
77 FJ40 front disk brakes, this have NOT been removed yet, but you can reserve them for yourself. These are set up to run the newer birf, and come with Aisan hubs. Aisan hubs were installed two years with a rebuild of the front axle. Rotors and pads less than 6K on them. $175
I'll take the:
FJ60 side cover
T-stat housing
air rail
vac line
smog switches
take paypal?
I will pull those parts right now, and yes Paypal is fine. Drop me a PM with a zip code and I'll get you a shipping quote.
Thanks
Air Cleaner ?
Is NAPA starter the reduction (small) one ?
91316 zip. :)
Air Cleaner ?
91316 zip. :)
Whoops I have an air cleaner with an OEM filter in it.
The Napa one is old style, non-reduction.
I'll take the Air cleaner . Condition OK ? Zip 91316
And if Splangy changes his mind on the T-stat housing, that too.
Thanks.
Ill take these
4. Front engine brackets w or w/o AC?
7. Bell Housing
Cheapest shipping to 92102
Smog pump no longer needed....thanks
If Spike Strip doesn't take the air cleaner, I'll take it. Do you have the hot air intake on the exhaust manifold? If so, I'll take that, and the hose that connects it to the air cleaner as well. Shipping to 80002..
THANKS!!
Splangy: Got your PM, and will have a quote for you tomorrow, your parts have been pulled.
Spike Strip: Air Cleaner is in good condition, happy to post picture if you would like, shipping quote tomorrow
In2Cruisers: Pulling your parts, and shipping quote tomorrow
-No AC mounts, pump turns freely counterclockwise.
Kurtnkegger: Sorry all those parts have already been sold, best of luck.
Flyguy: Pulling your parts, and shipping quote tomorrow. I have the temp sender, by cylinder #5.
No pic necessary - I trust ya ! Just PM a total.
Thanks!
Do you still have oil pan? will send you a pm
Thank you. Will stand by. R
All parts are pulled minus the oil pan and bell housing. I'm swapping around engine stands tomorrow and will have this up on one to get those final parts. Everything came off super easy.
More parts added at top.
Pm sent on the OEM starter...
Is the booster the big, original dual-diaphram? Those weren't available 1 year ago, AFAIK. Pics?
It is the original 2 dual diaphragm with a new master cylinder from Toyota. I can get pics of it tonight when I am home.
Splangy, Spike Strip, In2Cruisers, FlyGuy, Custyota, JLH911, Noodles40
All of you should have either an email or PM with a shipping quote. Let me know if you want to proceed. If so I will send you my email for Paypal and pack up parts this weekend.
If I missed someone let me know and I will get the need information to you.
Fast Eddy, here are those pictures.
