2F GM power steering bracket - no smog pump?
Tacoma, WA
So this might be an unusual set up but here it goes. I have a 2F that is and has been missing the smog pump since I picked it up (72 no smog needed in CA.) I can AND don't want to run the ps bracket from who ever makes those brackets that use the two head bolts. Even if I did, between the two front head bolts is some type of welded bolt that's at a 45* angle going into twoard the motor so unless i hack it off which Im not, cant even run that braket anyway. I will try and post up pics tomorrow.
So it seems the only option is to fab up a bracket that runs off the block using the mount for the smog pump. I have some ideas but heres the question. without the smog pump, I would also have to make a belt tensioner. Good thing is, I have the two groove harmonic balancer and water pump pulley. Anyone ever do something similar to this or have another idea that would be somewhat simple to make?
thanks in advance, mike
Most of my 2F power conversions (including all 4 of the 40's from the shop)... run the smog pump bracket for the Saginaw pump. Easy and clean... :D
Bill Dorry makes a very nice bracket that uses the motormount bolts to mount the pump. He includes all the hardware and instructions which is very helpful to those of us who are "afflicted"
Ed
wdorry@yahoo.com
I think about $90
sine80:"without the smog pump, I would also have to make a belt tensioner..."
Huh?
You won't need a belt tensioner if you make the new P/S pump adjustable with a slide mount at the top. Think you just about have to do that no matter how you mount the bottom of the pump.. :doh:
cruiseroutfit: Most of my 2F power conversions (including all 4 of the 40's from the shop)... run the smog pump bracket for the Saginaw pump. Easy and clean...
Do you mean the actual smog pump bracket? If so, I like this.
Got any quickie pics of the Saginaw in the Smog bracket?
Yup, the OEM bracket... of course this only works on de-smogged Cruisers. I have a 76' that we just finished up... I will try and grab some pics :D
honk said:
Huh?
Thats what I'm talking about. I would need to make a tensioner The pump I have is just the pear shaped GM pump and it does not have a tensioner. :grinpimp:
Thanks Kurt, I would like to see how this works too. I think I have a few ideas, but like what was said, "dont reinvent the wheel." Also Kurt, I sent you a PM about my axle.
Thanks fellas, Mike
