2F from 86 FJ60 to 78 FJ40?
Wisconsin
I have a chance at a 2F from a 86 FJ60, will this go into my 78 FJ40 without much trouble? Are the clutches the same?
Thanks
FJ40Jim
The Cruiser Whisperer
Lancaster, Ohio, USA
Yes, the long block is interchangeable. You may need to swap manifolds, bellhousing, motor mounts, accessory brackets, heater pipes...
That is a good upgrade, because the 85-87 2F has all the best/final upgrades before development stopped.
Southeast Overland
Get lost! Go explore!
SC
JimC (FJ40Jim) knows his stuff - listen to him.
I put a 83 FJ60 2F into a 1976 FJ55.
The biggest problem I had was having to source a fairly obscure water pump to fit - no other real problems besides that - oh, and did upgrade from a ballast resistor to a real coil and ignitor (I think I got that right).
But, I'm told a 40 has more room so the water pump problem for me might not be a problem for you.
