- Joined
- Aug 27, 2013
- Threads
- 5
- Messages
- 9
Hi all, new user here, first 2F, first post...
I'm looking for some advice about a 2F forklift motor that's being used as a stationary power plant.
It's been converted to propane and appears to be lower on power than I'd expect, and I'm looking for advice. It's not a lot low on power, and I'm not asking for a lot, but it just seems anemic.
I'm told it was gasoline only originally, but I'm not 100% sure. I think the mixer is an Impco 225 (or maybe a knockoff), which should be appropriate for the power involved.
I'm guessing that a different advance curve would be used for propane, but the engine will be pretty much single speed, so I'll just set the max advance and shouldn't have to worry about the curve.
The forklift exhaust manifold is an abomination, and it needs to have the exhaust re-routed anyway, so I'm planning on trying one of the cheap headers that I've found on the net. Is this a bad idea? It's not sitting on the original forklift engine mounts, which would be in the way of a header.
The forklift intake manifold sits lower than the auto one, so I'm worried about it interfering with the header. Does anyone have a regular intake manifold they'd be willing to sell cheap if necessary? I can make an adapter to fit the propane mixer, so it doesn't matter if it's single or double barrel etc.
I'm hoping that a tuneup and better exhaust system will get it running ok. If not then I can try shaving the head to bump the compression up, but I'd really love to find a quick & cheap solution without resorting to opening the engine.
I guess it's what everyone wants... Some cheap & easy way to get 20% more power without sacrificing reliability.
Anyone got any ideas?
Ramon
