Gretsch
Wondering here how important it is that the carb sight glass be sealed well. My carb sight glass seems to leak fuel pretty good. During the cold months, it seems like fuel leaks out of the carb via this sight glass when the truck sits. When I go to start it in the morning, it takes about 5 minutes and many tries to try and get it to catch and start up. Wondering if this is due in part to the fact the fuel bowl is being emptied overnight through the leak in the sight glass. Once she warms up after getting it started she runs fine until the fuel leaks out again while the truck sits. This takes a long time to happen (6-7 plus hours). I did a quick experiment yesterday before starting it. I checked the sight glass before trying to start it and there was hardly any fuel I could see in it. I pumped the pedal 4 times, checked the sight glass, and could now see the sight glass on the outside (as well as inside the glass)wet with fuel. I finally kept pumping the pedal until I could see fuel at the half mark on the sight glass. I tried to start the truck but again it was taking many attempts to finally get it to fire up. So it seems as though fuel is leaking out of the sight glass overnight. Can this be my reason for it being hard to start in the mornings? I know that some fuel can evaporate overnight even in a non-leaky sight glass setup. Could a leaky sight glass cause some kind of vacuum leak at the carb making it hard to start? Would having no fuel in the fuel bowl in the carb show up as these sorts of symptoms? Where can I get a seal for the sight glass on my carb? Is there a replacement sight glass kit available somewhere or should I just get some gasket material and try and replace the gaskets on mine. As always, thanks to the forum for replies.
