2F air cleaner warm air control (cracked)
Is the plastic warm air control mount on the snout of the air cleaner replaceable? Removed this component from the snout portion of the air cleaner but no part numbers.....You have to remove the entire air cleaner assembly and turn the air cleaner over to get a good look at all the moving parts.
This plastic holds the hinged flap, heat sensor and bi-metalic spring & has a crack in it. Would be nice to be able to replace just the cracked plastic part instead of the entire air cleaner...
Toyota still has some parts available. Just call them and tell them what your looking for. You may have to buy it off ebay or maybe someone has an extra part laying around that you could use.
