295/60r20 doable ? And tire pics needed
Oklahoma
Need some advice please. 2011 LX with AHC lift completed. Anybody know if the 295/60r20 in the Cooper AT3, load range e will fit or is a good option. I know it might be firm. I can’t find anything with the search feature in the forums on here anymore. I also cant see or get the tire database to work. The thread has no database or I am doing something wrong.
I have a set of 18 inch wheels off of a tundra I am going to get tires for mainly, but then I also came across a set of these copper tires at a great price if they will fit for my stock wheels, which I am painting black.
I am going to run 1.25” spacers to get both sets of stock offset wheels to poke a little.
Would really love pics and tire details of any 18’s and 20’s
LX members are running 295/70r18 with plastics trimming at +30mm offset. 295/60r20 specs a bit smaller diameter, so you should be fine.
It’s not just you! The tire and wheel database is referenced frequently but it must be a tightly held secret or not visible/linkable with iOS. I can never find it either, even with a google search. One possibility in your case is to run a search on mud for that tire size. If anyone else has posted pics you may be able to find them that way.
Here's a link to the post in the wheel database thread that actually goes to the right place.
Here's the only picture i could find. But a 295/60R20 is basically a 34x11.5. That's a pretty common size (in other wheel diameters) and easy-ish fit on a LX. Certainly will need to move some plastic, and on stock wheels will probably want a 1" spacer. The truck below belongs to an active member so he may have some thoughts on fitment. I'm about 80% sure those Tundra wheels are a +50 offset.
img_20191221_165447-jpg.2163571
