Can factory torsion bars be adjusted to accommodate 2863 springs in the rear. I’m contemplating moving up to them from 2866 with about 250 lbs in the rear. Goal is to make 295/70r18’s happen. Mall cruising mostly
The disclaimer is crucial, thank you.Can factory torsion bars be adjusted to accommodate 2863 springs in the rear. I’m contemplating moving up to them from 2866 with about 250 lbs in the rear. Goal is to make 295/70r18’s happen. Mall cruising mostly
Toyota OEM non-AHC spring heights:IDK the actual stock spring measurements
Closer to 200 actually.Toyota OEM non-AHC spring heights:
Driver Side = 492mm
Pass Side = 486mm
OME spring heights:
He said he’s hauling 250 lbs (I assume constant load), so 863s fit the bill, given their 250 spring rate.
then get the 860s instead...your first post says 250Closer to 200 actually.
My bad it was cuz I double checked my math and wanted to clarify in case it mattered. Which it did per your clarification. Thanks a tonthen get the 860s instead...your first post says 250
That’s a lot of height even with that weight. Great to hear you were able to re-index factory tb’s. I don’t have a front bumperHere is my old truck with 63's in the back. slee bumper, 295/75 spare and a hi lift. and as you can see it still has a good amount of lift.
I also have re-indexed factory torsion bars up front in this photo.
