Bought a OME 2.5" heavy all around lift.
Going to go with 285's...
Which tire would you get?
Note: This feature currently requires accessing the site using the built-in Safari browser.
I have had a set of duratrac's on one of my landcruisers for about three years. Great multi-use tire, drove across the US twice on them, good highway behavior, have had them off road, worked great, and best snow tire I have ever had, bar none. Reportedly have weak sidewalls so may not be the best choice in areas where you have a lot of sharp rocks or other objects that can penetrate the sidewall, but I have not experienced this myself. Other tire you may want to also consider is Toyo AT II.
Another data point:
A local mudder has 285 DTs and they do fantastic on the snow/ice. However, they're prone to punctures and I think he lost two tires. He also had a bit of a time trying to get Discount Tires to balance them. They're just not quite right according to John.
Not related to your question but just another data point: I've had a set of 315 Nitto TG since '09 and have yet to balance them or get a flat. However, I do zero mud wheeling. My TGs are made in the USA and I'm going to buy another set shortly...once I sell another kidney.
I will report back with how I like them
They do have 315s... I have a set & Lovem!!! They are a true hybrid tire.I like that tread pattern, post up how you like them once you get some miles on them. Doesn't look like they have 315's though.
They did great in the mud! Hopefully you can test them again at the Christmas partyI've had 315 ST Maxx on for 5 months now and wheeled them about 5 times. They've been fantastic. Even did surprisingly well in the local clay on a wet but not raining day.
