So I got a fire sale deal on a windshield frame from an fj40 in perfect shape with the wiper motor and the arms. It's out of an older fj40. Problem is I have the motor but it's 12 volt. I also have the old 24 volt motor but they aren't interchangeable. Worse yet I don't think I can find a 24 volt motor for that style and even if I could it would probably be very expensive. I have them apart and the armatures look exactly the same except the 12 volt having more windings and the shaft on the 24 volt is longer. So how can I make this thing work? My options so far are:
1) run the 12 volt motor on 24 volts and see what happens
2) Cut the shaft on the 24 volt motor, jimmy rig it and make it work. I could probably do this but wouldn't win any car shows.
3) Converter. I don't really want to buy one just to run my wipers
4) Rain-X......I want to avoid this one. Even though it's been instilled into my head I need to hate mud, I still expect to see a lot flung on my windshield when I'm duck hunting.
Maybe I should start crawling before I walk here. What makes the difference in a 24 volt motor and 12 volt motor? So far the only difference I really see is the 12 volt motor has more windings. I would suspect since a 24 volt runs with less amps, running 12 volts through a 24 volt motor is a bad idea. But running 24 volts through a 12 volt motor might be ok. I'm at least 8% sure on that conclusion I drew.
