Hella 24V 10/20A relay part number = 87426.
Pin 86 = connect to +24V lead that is hot when the ignition is in ACC.
Pin 85 = connect to chassis ground.
Pin 30 = is the supply pin. Supply with +12V (constant) from your 24-12V step down converter.
Pin 87 = is switched power. Will have +12V when the relay is activated by ACC ignition position. Connect your stereo IGN lead to this pin. If you want ignition switched +12V for your cigarette lighter, you can also replace the (+) lead at the back center of your cigarette lighter and hook a lead up to this pin.
Pin 87a = leave this pin empty. Make sure that it does not short out to anything as it will have +12V when the relay is OFF.
*Remember to have a fuse somewhere inline to the wire supplying Pin 30 with power.
