I finally finished installing my new 24v ARB high output compressor in the HJ61. Because of all the AC lines and wiring I had to come up with a riser to mount the compressor on which also gives it some more distance between it and the turbo. (pics to follow).
So I wired the compressor up just as ARB indicated, flipped the switch and nothing. I took a closer look a the wiring diagram and my worst suspicions were confirmed; ARB does not make any allowances for 24v on the solenoids/switches/relays/etc. (they are all 12v) therefore it is a dual 12v/24v system no matter what. The diagram shows a centre tap for 12v on the diagram but because I was using my 12v/24v transformer for the switched 12v source the system was not grounding properly. I rewired it as shown in the attached sketch as it worked great. I had to wire the blue-white wire (dash lights) into the transformer as well.
Now I understand that ARB is keeping things simple by offering the solenoids/switches/relay as 12v but it certainly complicates things when installing in a 24v vehicle. I can however, comfort myself in that if I ever need parts there should always be 12v ones around. I just think that they should revise the instructions for 24v vehicles, I mean where are you going to get switched 12v let alone 12v dash illumination circuit on a 24v truck? I will have to send them an email. I hope the attached diagram helps someone else out in the meantime.
Anyway, now that the hard part is done I just need to run/hook up the airlines and the 61 will be locked front and back.
