I'm wondering if someone can help me with a problem. I have a Powerstream 24 - 12 volt converter. I have been using it with no problems for a little over a year. Recently my alarm and stereo both stopped working. Actually my stereo would come on for a couple of seconds and then shut off, come on and then shut off... and so on. I checked the voltage going in = 24 volts consistently. The voltage coming off the converter fluctuates between 13.8 and 9 volts every couple of seconds, hence the stereo coming on and shutting off. Then I checked the same thing with the engine off and there is no problem... the stereo works fine. So the converter only has this problem with the engine running. I have double checked the ground to the converter and am confident that it is good. I don't know what is going on.
Any suggestions????
Thanks.
Any suggestions????
Thanks.
