22mm or 24mm bolts on 40s? (1 Viewer)
Alton, IL (near St Louis, MO)
I have a chance to get some larger size wrenches for a good deal and wonder if there are 22mm or 24mm (or any other size in that ballpark) that are on our trucks. I have a 74 with a 2F, 4 speed.
Just don't like to buy anything I don't need or will not use.
I know that the u-bolts on my springs are 22's if that helps, otherwise I have not used higher than 19 lately but I'm just a home garage tinkerer.
I think it's a 24...but could be a 22 on my oil pan drain plug, same on the diffs. 2/'75 40.
John
24 and 32 for the TC if I recall
The diff, transmission, and transfer case fill and drain plugs are all 24mm on my 1980.
All good info, I appreciate everyones input. Please keep it coming. I have a chance to get some closed end Facom wrenches, 13-17, 18-19, and 22-24. Think I'll take em.
I use a 22mm quite a bit (most recently on the center arm), and the other day I was trying to get the nut off the pitman arm with a 32mm (wouldn't budge:mad:)
