After more research it seems like these will work fine without any rubbing as long as I don’t use spacers.
From previous posts I found, running 1.5” spacers work with a little rubbing on plastic fender liner on 75% lock.
I’m going to try these without spacers and will share the before and after when I get it done.
I’ve never run spacers on a car before. Is they anything I need to know?As long as the tire size is 33" or smaller, and 1.25" wheel spacer or less, they should fit without rubbing.
To get the hub cap to fit you will need at least a 3/4" spacer (I think...). Most people run a 1.25" spacer because it puts the wheels/tires at a really good stance but not a typical bro-dozer tire poke level. You can see in the picture that @Tmparker05 posted he doesn't have the front hub cap on because the dust cap won't allow it to seat.
I’m assuming most people run on all 4 wheels?
