2016 to 2020 Key Fob Upgrade
Think the one with the power door button is the only one you can choose if you want to keep the alarm Button. The install especially with the tape seems a little bush fix. But think that’s the only way to hold the battery in as the key shape is different.
This link has a video showing what I’ll talking about.
US $13.44 36% Off | OEM Car Key Case Key Shell Holder Upgrade For Toyota Land Cruiser 200 FJ200 2008 2010 2011 2012 2013 2015 2016 2017 2019 2020
82SC and luke27617 - really appreciate the feedback. I was looking to change key fob as I’m not a fan of the cheap looking fob that came with the 2016. Trivial I know...I’m just not a fan.
Good to know on the size of the newer key fob. With the offers local dealers are throwing out for my 2016, I’m now contemplating upgrading the key fob and getting a new LC to go along with it :)
I bought one of the 3 button fobs, the newer style (just liked it better too) and apparently nobody can program this thing. Took it to my local Toyota dealer, they won't program a key from the outside, so I drove to the local Lexus dealer where a buddy of mine works, and it has a different number, so it is un-programmable. Trying to figure out what my options are from here...I figured if the Lexus credit card key would work, this should too...apparently I was wrong.
I got mine from aliexpress. Of course it’s a knock off but it does it’s job.
There is a silicone insert that fits the old key fob hardware and it works great. So no more rubber band needed to hold the battery in like some of the older versions of this.
Also no reprogramming needed just need to swap the internals
I like it because it doesn’t look as cheap as the stock 17 key fob
It is slightly bigger and has a little heft to it which I actually prefer and harder to misplace
The rear hatch door obviously doesn’t work.
the key blank is 2 sided. Mine is one so that is a downside. I emailed the seller and let’s see if there is a solution to this.
I know there is a mudder here that sells a titanium and kydex key fob cover replacement looks a bit beefier and tacticool.
Check out the Yotamd key fobs for an excellent solution.
