Does these parts fit 2016+ LC with larger OEM calipers?Pads: Toyota TRD
Front: PTR09-0C111
Rear: PTR09-0C110
They should - 2016-2019 TRD Brake Pads? - https://forum.ih8mud.com/threads/2016-2019-trd-brake-pads.1151455/post-12501204Does these parts fit 2016+ LC with larger OEM calipers?
Edit - calipers
If your vehicle has spent any significant time where salt is a thing you should consider front caliper pad pins and springs. For the rears there are some bent-stainless inserts that go into the pad brackets to control wear.. cheap and clean surfaces for new pads. Again if corrosion is a thing you may be looking at slide pins for the rear calipers..I'm looking at these as well. If I want to replace the OEM brake pads, do I just buy the pads? Do I need anything else?
Are you sure about that?Stoptech Fleet pads with the 306 prefix are the same compound as the TRD.
