2014 headlight install
Saratoga Lake, NY
I pulled off the pass. side low beam dust cover and stopped there. I searched you tube and found people talking about the installs but no video of the process.
Bought these bulbs to install. How do I put these in? Thanks.
Unscrew the water resistant plastic cover. The braided wire on the cover is attached to the ballast (the little gray box) inside the light housing. Turn the ballast about 1/4 turn clockwise and it will come off in your hand. Attached pics are of the pass. side low beam bulb with the ballast removed. Loosen the screw at the bottom only enough to get the wire clip loose. The clip is V shaped and pulls out at the top two ends. Also it has to come off to get the bulb out and only goes back in one way .
I stuck a paper towel in there to catch what ever fell. It was a good idea.
When reinstalling the clip I had to do it by feel.
I'm not going to say not to touch the glass.... on the new bulb.
