elcie200
Looking for suggestions on next steps, things to pay attention to, etc
2013 LC 104k
On the one hand, I feel like I dodged a bullet (or two): valley plate, head gasket.
On the other, I'm paranoid if I should be more concerned about this apparent "air pocket"
Any advice, things to follow up on, monitor, look in to etc from the great Mud hive mind?
Thanks!
2013 LC 104k
- Got the truck in May 2018, no issues/problems observed
- June 2021: replaced the radiator due to the beginnings of the radiator crack at "shop1"
- No issues/problems observed at that time.
- No overheating etc.
- Starting approx May 2023 (2 years later), observed low/empty coolant in the reservoir. Filled, to F, drove, it dropped to L, or slightly below L. Over the course of a week, had added approx 1/2 gallon of coolant. It intermittently drops to L (after filling about half way up) Sometimes it holds for a day or more, sometimes it drops between two trips on the same day. Kinda random.
- Feared the Valley Plate Leak; No visible leak ("shop2" confirms this is not valley plate)
- May 23, 2023 had coolant system tested at "shop2", 15psi; passed test. <-- good small Toyota shop reco by friend who takes his Tundra there
- Shop suspects could be head gasket and recommends leak down test to confirm/isolate
- May 31, 2023 coolant system re-tested: passed; block test: passed. at "shop3" <-- good known toyota shop; used to take my 4runner there back in the day.
- Leak down not conducted as block test passed
- Shop put the truck on an incline, heater running, system "burped" (found air pocket); added coolant to F line
Thanks!
