- Year
- 2008
- Vehicle Model
- 200 Series
- Location
- Lubbock, Texas United States
- Mileage
- 121500
- Color
- rgb(213, 215, 161)
It’s time to move on to another project. I’ve decided to list my 200 for sale. It has been an absolutely perfect vehicle. Don’t have a need to sell, but I get the itch for something new every few years so here we are.
2008 URJ200
VIN JTMHY05J384000334
Miles 121K (Will change, it is my daily driver at the moment.)
Price: 43k (Is negotiable.)
I am the third owner of this vehicle. The first owner purchased in late 2007 and kept it for roughly eight years. In those eight years only 16k miles were put on the vehicle. The second owner put the bulk of the miles on. I purchased it in may of 2020 with 93k on the odometer. During my ownership there has been a good amount of work done to the vehicle. Most of the work has been done by me with the exception of alignments and one repair performed right after purchasing. All work not done by myself was performed at my local Toyota dealer. No accidents on this 200. Attached is a google document with photos.
Below is a list of items that have been repaired or replaced.
The Bad
2008 URJ200
- Exhaust manifolds replaced due to a pihole leak on the driver side manifold. Air injection pipes behind the engine were also replaced at this time.
- Starter replaced with updated part as a preventative
- Radiator (updated part.) Radiator hoses and clamps, thermostat, water pump and heater hoses
- Spark plugs
- PCV Valve
- New Toyota Super Long LIfe Antifreeze used
- Serpentine belt, belt tensioner, fan bracket, fan clutch, idler pulley
- Intake manifold gaskets were replaced due to manifold being removed for valley cover plate leak inspection
- Differential fluids and Transfer Case fluid replaced
- Power steering fluid flushed
- Front lower and upper control arms
- Inner and outer Tie Rod Ends
- Sway bar bushings and link, front and rear
- New rear cam bolts for front control arms
- Brake rotors and pads, new brake hoses throughout
- Parking brake shoes and hardware
- Brake fluid flushed
- New OEM CV Axles
- Both air pumps, pump driver modules and breathers
- Ironman 2in Lift with rear Track/Panhard Bar
- SPC UCA’s
- Prinsu Roof Rack
- Ironman Bullbar with Baldands Apex 12k Winch and spot lights
- SLEE Group 31 battery tray and compressor mount
- ARB Single Compressor
- Auxiliary accessory switch panel
- Diff Drop
- Re-geared to 4.30s
- Ironman Twin Drawers with Fit Kit
- Ironman LED Fog lights for bull bar
- SDHQ Air Pump Snorkel Kit
- Dobinsons Snorkel
- New Non-US Toyota headlights with wiring harnesses
- LED Bulbs in interior and headlights
- 5 Method Wheels (+35mm offset 17x8.5) with Nitto Ridge Grapplers (285/75R17) installed less than a month ago
- Red Arc Tow Pro Elite brake controller
- New OEM rear bumper cover with associated parts. Had a rear bumper installed, decided to return to OEM setup
- New Back Up Camera installed
The Bad
- Slight tear in the rear of the passenger side seat (Shown in one of the photos.)
- Some of the door panels have markings on them, this was present before I purchased
- A few rock chips that have been touched up with touch up paint
- Driver rear outer tail light has a start crack, I did not notice this until after I had purchased
- Rear parking sensors are not present. These were are back order at the time of returning the rear bumper to stock. Have a new in box wiring harness for them
- Passenger rear door has a roughly three inch long door. Not noticeable unless pointed out
- There is a lien on this vehicle still. Will have to be paid in full to receive title.
