BadReligion
I looked at the pros and cons of both and ended up going the front for a number of reasons;
In reality, I'm sure a rear would have been a huge step up too, but the front just made sense for me. I will be going a Harrop E-Locker for the rear when funds allow.
- The IFS doesn't allow a lot of flex up front (in comparison to the rear) so you're more likely to lift a front wheel.
- The front dif is weaker than the rear, so additional momentum + lifted spinning wheel before re-grabbing traction is more likely to equal a BANG.
- Rear is equipped with a (s***e) LSD already
- I've got a full time mechanical locker (due to price) and didn't want to run that in the rear due to on road manners, however it doesn't matter in the front as I've got a part time 4x4 conversion.
Or, get a front locker and wire up a disable TC switch like I have done. The LX is so much more capable now. Some people might like TC systems, but they're not for me.
I'm not claiming to be an expert on how/when/what to use for lockers, but I've run enough trails that require frequent use of both lockers to get a good idea of how they work, and what happens when you do not use them correctly. I dont know a single person who is front locked only. You agree that the front diff is weaker than the rear, so why would you want to lock that first?? If possible, you want the weakest axle to be able to spin (and release energy) before it breaks. Thats why when navigating an obstacle, you lock the rear first. The rear is obviously stronger so if a single rear wheel is able to give you forward momentum, the rear locker did its job. Not to mention with most situations where a locker is needed, you are traveling uphill and the majority of the vehicles weight is on the rear axle. This is where your best traction is.
I agree with you that wheel lift can be an issue on IFS, so why would you want all drivetrain stress on a single wheel on the weakest axle on the vehicle? I'm just trying to understand your thought process here. With a LSD or open rear, and CDL engaged, if the rear has no traction and the front is locked, guess where all of the power is going?
I also dont understand why you would run a full time locker up front. Even with a part time conversion, ANYTIME you are in 4wd, the front is locked. I guarantee the lifespan of your front axle can be measured in hours or even minutes on just a moderately difficult trail....unless it is in a perfectly straight line.
