2006 Bluetooth phone system problems
My Treo 650 doesn't function with the LC's NAV/Bluetooth system. So I went out and got an additional phone line and a Motorola V3 which does operate with the LC's system. The nuisances are:
(1) I can't seem to be able to download the address book numbers from the V3 to the LC
(2) Whenever I pull the key out of the ignition, the phone call disconnects
Most frustrating though, has been the fact that I can't make any calls other than "last number redial" when the LC is in motion. So even though I've loaded onto the NAV a bunch of one-touch dialing, I can't call those numbers unless the truck is stopped.
Is there a way around that? Seems like they did that to prevent people from making calls while driving. So what do I do? I flip open the V3, dial manually or search through the address book - even less safe to do.
Also, I've been a friend's Acura RL, and it had a voice activated dialing - say "Call So-and-so" and it would dial it. I think the LC's is simply for the Navigation system.
Any solutions? Thanks.
I have an Audiovox BT. and I am able to place calls from the Pre-asighned #s. push the talk button on the wheel, and choose the person you want to call. As far as the disconnect, you have to wait a bit (5s for me) for the call to be transfered to the handset from the car. I was unable to transfer the phonebook from the Audiovox, and had to use a friends Sony-Ericson handset to do the transfers...anoying things, but does ok now.
SF_cruiser,
From what I've read and attempted, you can only transfer one contact at a time. I've been using a SCH-1730 PDA/Phone (Windows Mobile O.S) on my 04 LX470. I had to beam each contact thru a "beam contact" function in Outlook. Even then, the phone number needed to be in a special field in order to have the LX recognize it. I also know that Verizon Wireless (my carrier) has a habit of modifying the phones so that not all intended features get released.
In order to deal with "can't dial while in motion" issue, I did the DVD/Phone Hack. It involves removing the Nav screen unit from the dash and cutting two wires (speed sensor and brake) and grounding one. You can find the details here: http://us.lexusownersclub.com/forums/index.php?showtopic=16189
This allows you to play a DVD while in motion and more importantly to be able to dial out while in motion. What I don't know is if Toyota modified the Nav system in the 06s to prevent customer from doing this fix.
There's a guy with an 06 LX who was asking the same question. I have made a post pointing him to the fix and asking him if he figure it out.
http://us.lexusownersclub.com/forums/index.php?showtopic=24807&st=0&p=165719&
Keep us updated on your findings!
