Hey fellas, any help on these error codes would be great. I know what the error codes are but which one to attack first? Is the P0138 causing the P0606 or P06060 causing the P0138. Should I replace the O2 Sensor due to the O2 Sensor Circuit High Voltage (Bank 1 Sensor 2) or is the PCM causing the sensor issue. I had reset both the errors and the P0138 came back first and then the P0606 showed up. Thanks for any help.
