- Location
- United States
2004 Toyota Tacoma 2.7l 4cyl 3RZ-FE SR5 4x4
PRICE REDUCED
Asking 9000$ OBO
Currently has 177,000 mi and will be increasing as it is my DD
5 speed Transmission
Manual windows, locks, and mirrors
Frame replaced by Toyota
Non Smoking vehicle
Religiously washed the underside after each snowstorm, including the insides of the frame rails
Work done in the last year:
Marlin Crawler Heavy Duty clutch kit, also replaced pilot & throwout bearing
Both Lower Ball Joint
Both Outer tie rods
Sway bar end links
New CV axle, driver side.
Alignment
Coolant Flush, replaced upper and lower radiator hoses
Upper and Lower idler pulleys/mounts
New windshield
Spark plugs
Front Brake pads and rotors
Old man Emu AAL installed
Known problems:
The only engine code that comes up is P0135, and its a malfunction of the circuit that pre-heats one of the O2 sensors, however both sensors work proper, as i was assured this by a professional mechanic.
A/C will need to be recharged.
Some rust on the bottom of driver/passenger door, as well as some on the pinch weld on the body below the doors.
Tires are under 50% tread.
Modifications List
-Old Man Emu 2" Suspension Lift w 881 coils, Dakar Leaf pack & Add-A-Leaf
-2" Diff drop kit
-Light Racing Upper Control Arms
-Superbump Bumpstops
-Relentless Fabrications powdercoated Rear Bumper
-Marlin Crawler Heavy Duty Clutch kit
-ARB Dual Compresor w/ Tire Inflation kit
-Heavy duty wires to replace original witing harness, with aftermarket battery terminals
-PRINSU powdercoated Roof Rack
-Scangauge II mounted on steering wheel
-Weather Tech Floormats
-ARE Fiberglass Cap w/ sliding-vented windoors
-Red Line Tuning Gas struts on hood
-Pop & Lock Tailgate locking handle
-ARB Rear Differential Breather
-Mac's custom tie downs Aluminum tracks on inner bed rails
-Drawers and platform in bed, with hardwood birch plywood made w/ soy based fermaldahyde free glue, and stained with two coats of low VOC 100% biodegradeable oil/wax.
Repairs/Maintinence/Modifications Timeline
Oil & Filter change, grease driveline, grease Upper Ctrl Arms & Rear Shackles (moly specific), and tire rotation every 5,000mi, and airfilters replaced when necessary. All non upgraded parts replaced with OEM parts, except for the MOOG greasable sway bar end links.
129,000 Complete frame replacement from Toyota, including new brake lines.
139,800 New BFG AT KO2 235/85/r16 (31.7") x 5
140,400 Alignment, installed Macs Custom Tie Downs aluminum track to the inside of the bed rails. Weather tech fitted floor mats. 3M Ceramic series 20% window tint applied.
141,300 Relentless Fabrications powdercoated 3/16" steel rear bar w 3/4" smittybilt D shackles. Installed Red Line Tuning gas struts for the hood.
144,000 Replace reverse switch on transmission/tighten belts.
145,000 Old Man Emu 2" Suspension lift including 881 coils, dakar leaf pack w/ greasable rear shackles, rear struts, U bolts, BPV relocation bracket. Wheelers offroad superbump rear Bumpstops Light Racing Upper control arms, for proper alignment (greasable). Rear Differential oil change. Differential drop kit installed. Front diff transmission/transfer case oil chaged with Royal Purple, replaced front diff drain plug. Alignment.
148,000 Replaced Carrier (center) bearing. Fiberglass A.R.E. Cap w/ sliding vented windoors, sliding front cab window, Thule rack tracks, installed and made watertight by dealer. Has not been removed since.
150,000 ARB Rear Differential breather installed,plumbed to the top end of the firewall, under the hood.
152,000 ARB Twin compressor on a universal mount installed. PRINSU roof rack install. ScanGauge II installed. Pop lock tailgate lock added. Balance wheels.
153,400 Old Man Emu Add a leaf installed. replaced passenger side steering rack boot.
154,000 Front pads and rotors changed, Checked for play in all wheel bearings, none found. Changed spark plugs. Plenty of shoe left in rear drum brakes when inspected.
155,000 Replaced transmission with a Marlin Crawler Heavy duty clutch kit. Replaced driver side parking brake pivot arms & springs. Removed corroded old wire harness and replaced with large heavy duty wiring and new aftermarket battery terminals that are designed for ease of wiring in accessories.
170,000 New outter tie rods, left and right. New Lower ball joints, left and right. Replaced upper idler pulley and mount.
171,000 Alignment
172,500 Coolant replaced, and flushed system, replaced upper and lower radiator hoses. Replaced brake fluid. Replaced driver side CV axle.
175,000 New MOOG greasable tie rod end links. Replaced Lower idler pulley. New Windshield installed. Oil change/filter, tire rotation.
I have two Corbeau GTS II seats w/ mounting bases for this style Tacoma, in like new condition that can be thrown in for some extra $$$.
I thought id have this truck for a very long time, and i treated it so.
Wheels are well balanced, alignment is spot on, and i wouldnt hesitate to drive her cross country spur of the moment.
View attachment 1869966 View attachment 1869967 View attachment 1869968
PRICE REDUCED
Asking 9000$ OBO
Non Smoking vehicle
Both Outer tie rods
Sway bar end links
Alignment
New windshield
Spark plugs
Known problems:
Modifications List
-2" Diff drop kit
171,000 Alignment
