Got a 2004 Lexus LX470. Few weeks ago I got the AHC to function for the first time in like 10 years by replacing the 20amp AHC-IG fuse that was missing. The car went from empty shocks and bumpy ride straight to N position and is holding at N position, it drives fine, doesn't feel like a pogo stick or anything, everything is all good. So i'm a curious person by nature, i'm the guy that's always like "well what does this button do?" So i go to press the AHC switch just next to the gear selector. I press the up button and look at the AHC dash indicator, no change, no pump movement, nothing. I press the OFF button, no change, no movement. I turn the knob from comfort to sport, nothing. I turn it back to comfort, nothing. I (very very tenderly) mash the down and up buttons, no change in anything. Anyone know what the issue is here?? Here's a list of things that has been done:
During all this testing, I was the only person in the car (I weigh like 115 lbs), everything on the car is stock, no aftermarket bumpers or weight or anything, all doors were closed, car was in P position (without parking brake up) and brake pedal was never touched.
Checked the AHC dash lights (via turning key to ACC position) and all AHC dash lights (including OFF light) flash on as they should.
I checked fluid level in AHC reservoir, seems to be just below MIN line but not sure if that's the actual level or if that's just because the container is stained.
Connected the pump directly to the battery and it runs fine but of course no fluid came out of it for some reason.
Shorted Ts and E1 pins in DLC1 located at engine bay wall around the air filter housing and tried to put the AHC into test mode. Started the car, dash lights up like a christmas tree. (very tenderly) Mash the down button at least 5 times within 5 seconds of starting the car and still nothing.
Found the most level surface you could imagine, tried operating the AHC via the switch and still nothing.
Both front height sensors have been brought out and thoroughly cleaned and sprayed with electrical insulator and correctly replaced to their respective sides.
AHC ECU has been checked and works fine.
Brought out the switch and sprayed electrical insulator on the male and female electrical connectors to it and let it sit for 5 mins then coupled it back to it's original state and still nothing. Let it sit for a day and still nothing.
Honestly i'm at a total loss. The next thing would be to get an OBD-II dongle and hook up techstream (don't ask how i got techstream lol) but yeah that's not really an option as that's up to my dad who's not as enthusiastic as we men of culture :/
Any help or suggestions would be greatly appreciated. Tomorrow is the perfect day to work on this! Cheers!!
