I have a 2004, 100 series LC and there is no A-Trac feature although I believe that other models came with it. I do still have diff lockers. Is this normal and is there any pros/cons to this?
Diff lockers (plural)? Or diff locker (singular)? US Spec LC 100 2000-20007 had ATRAC and a center diff lock. If you have an 04 it came with ATRAC and a center diff lock only.I have a 2004, 100 series LC and there is no A-Trac feature although I believe that other models came with it. I do still have diff lockers. Is this normal and is there any pros/cons to this?
It is registered as an 04, I bought it as an 04, and all of the owner manuals state it's an 04 so I'm not sure why there is no A-TracUnlikely. Why do you say that? Maybe you have a pre-2000 instrument pod?
I only have a center diff locker button and no A-Trac. Other models I believe came with a dial rather than a button.Diff lockers (plural)? Or diff locker (singular)? US Spec LC 100 2000-20007 had ATRAC and a center diff lock. If you have an 04 it came with ATRAC and a center diff lock only.
Go hammer down the gas pedal and turn the wheel on a dirt road, you will find out you have traction and stability control but there is no button to turn those features on and off.I only have a center diff locker button and no A-Trac. Other models I believe came with a dial rather than a button.
Because he doesn't see the button for ATRAC.You still have not told us why you think you don't have A-Trac. What's the evidence? Post your VIN number.
