2004 Land cruiser thug sound
Discussion in '100-Series Cruisers' started by ADEEL, May 16, 2018 at 12:23 PM.
  1. ADEEL
    ADEEL
    6
    Wednesday
    Houston, TX
    I have a 2004 Toyota Land cruiser. The truck runs excellent and i have had no issues what so ever and have kept up with routine maintenance. A key issue i have noticed that when i am moving at a steady speed and if i have to give gas i hear a "thug" sound as the transmission engages. Same is the situation when i am stand still and want to move quickly i hear the "thug" sound. Transmission shifts perfectly -- no slippage what so ever except a thug.
    Any suggestion / recommendation would be highly appreciated.
  2. CanadianRockyCruiser
    414
    130
    Oct 13, 2011
    Calgary, Alberta
    Check your universal joints first... cheap and easy to replace :)
  3. ADEEL
    ADEEL
    6
    Wednesday
    Houston, TX
    Thanks -- i will forsure have them checked out.
  4. custyota
    custyota Meatball SILVER Star
    4,715
    1,624
    Sep 5, 2009
    San Diego
  5. fooldall1
    fooldall1
    453
    Albums:
    1
    101
    Jan 27, 2017
    Orlando, Fl.
    Grease the Drive Shaft zerks, all of them- as directed. SAME EXACT issue for me, I greased them all 6 months ago and no noise since. Now, when going from R to D when driving, I get a clunk from the front diff bushing needing replacement (nothing serious).
    Trust me, it 's a cheap fix and makes a world of difference.
  6. ADEEL
    ADEEL
    6
    Wednesday
    Houston, TX
    Hi CanadianRockyCruiser,
    How many u-joints am i looking at changing.
    Thanks - Adeel
  7. ADEEL
    ADEEL
    6
    Wednesday
    Houston, TX
    Definitely - that would be a easy fix -- will have it greased up this weekend and see how it reacts
  8. CanadianRockyCruiser
    414
    130
    Oct 13, 2011
    Calgary, Alberta
    Up to 4... I would inspect them first, because it's likely only one of them causing your issue. If you note play in them when manipulating by hand, then it's safe to say that is your problem. Just try twisting the axle both ways by hand: if you find play in one side of the ujoint, that might your problem. I'm hoping that it's Ujoints, because they are much cheaper to fix than transmission components.
    You can buy aftermarket sets of all 4 for about $100 or spend a bunch more on factory parts. Sometimes the Ujoints can be a pain to remove.
    [​IMG]
  9. ADEEL
    ADEEL
    6
    Wednesday
    Houston, TX
    Thanks -- much appreciated.
  10. milkyxj
    milkyxj
    163
    Media:
    1
    186
    Sep 10, 2007
    Anchorage, AK
    And I came here looking for a sweet subwoofer install....
  11. CanadianRockyCruiser
    414
    130
    Oct 13, 2011
    Calgary, Alberta
    If it sounds like this, you have much bigger problems...
    tacoduck likes this.
  12. JJ_SC
    JJ_SC
    119
    Media:
    1
    38
    Jan 19, 2006
    Santa Cruz, CA
    I had a clunk that sounds similar to what you described. It was the bushings in the rear control arm that had gone bad. Might be another place to check.
  13. ADEEL
    ADEEL
    6
    Wednesday
    Houston, TX
    Thanks -- i will get that checked out as well.
  14. tacoduck
    tacoduck
    799
    293
    Apr 7, 2015
    I didn't choose the thug life, the thug life chose me.
