150k miles
occasionally get the good ole CEL with codes p0441, p0442, p0446 with VSC Trak and VSC Off lights. I hooked up techstream per the FSM and ran the "EVAP SYS CHECK". I had to manually go through each of the 11 tests. The auto test function was not available. The FSM does not mention how long to run each test. I arbitrarily picked 15 seconds each. The pressure stayed between 772 and 775 or around 10 on the pressure gauge.
The FSM does not mention what the values should be or how to interpret.
Any ideas?
Any ideas?
