I was trying to change brake pad because I found that my caliper is grinding the rotor. While changing the brake pad I removed 2 screws 17 and 14mm on the bottom of the caliper then I started to remove the top one and clips and pins..
Then brake oil started to leak and when I placed the new pad, I found my old pads was still very good. I wonder why I grind my caliper and why the brake oil leaks?
I guess I need to call the tow truck if I can't figure that out.
