Hello everyone - my first post -
My best friend has a 2001 land cruiser 4x4 (heading says 2002 trying to change that) About six weeks ago he was driving alone in Elijay GA on the road and it felt like if stumbled for a moment and lost power transfer. His description. Would shift visibly into all gears but wouldn’t take an gear.
He had it towed to Chattanooga to a shop where it sat for 4 weeks or so and all they did was verify the linkages were intact. Bummer to say the least. This is a second car/toy to him so he used the tundra in the mean time.
I went to inspect and found that the flex plate was still turning the converter smoothly but it makes a metallic sound inside at the front. I have long suspected a bad converter. Shifter moves but gets no power transfer from engine. Only rattles with inspection cover removed and engine running/shifter action
Second shop suggested it needed a rebuild as well. All invoked suggests it’s 4-5k for a trans plus labor.
I was reading the stator pump may also be bad, maybe no fluid pressure similar to a bad converter.
Vehicle is just two owners with a mountain of service paperwork. About 220k miles and nearly immaculate. On road most/all of its life clearly. Clean dry and tidy underneath. Plenty of fluid and history of service.
Seems reading it has a 343f transmission. My questions are: 1) whether or not this is likely converter or stator (it will not take any gear, no dash light) 2) if input an OBD tool on it could I expect to get any other codes? 3) is the “340 family” such that I could use a “non 343” and bolt up his transfer case and swap with a unit from other things in the family? 4Runners seem to have some family transmissions and are common at pick a part etc locally. We really hate to have a $5k bill on a 11k truck (but isn’t that problem as old as the automobile in a way!).
If anyone can give advice on this we are really struggling with how to proceed. If a rebuilt unit is best I’m also open to safe advice on where to get it!
I’m the mechanic in this and I’m totally happy with all kinds of heavy swapping but I have NO experience with these trucks specifically so any advice is well-appreciated.
Thanks all!
Thanks all!
