I have a clunk when shifting from park to drive or reverse to drive. I have narrowed the noise to the front diff. A closer look showed when I lifted the front end and turned the front right tire about a 10-20 degrees; I saw no movement he output shaft of the front diff. I then poured the oil out and saw no sign of wear. Just in case I also checked the transfer case and saw no backlash also the U-joints look fine. Not sure what can cause this other then maybe the drive pinion came loose and increased the original backlash. I haven't pulled the front cover off, don't know if it will come off easily but that might be my next step anyway. Any thoughts?
Also I was looking for replacement diffs, I didn't see a compatibility list anywhere on Ih8mud, is there one?
Thanks Mark
Thanks Mark
