I recently purchased a 2001 Tacoma PreRunner 2wd. It now has 131k miles, after over a 1k road trip as a shake-down run. Between getting an inspection, before, and the road trip, I have a list of issues to replace on this rig, and am hoping to get some feedback from the experts. I have done some searching and have identified some common issues with these rigs in addition to the other issues.
So, to start, on to some background on the truck.
-It's a 2001 Tacoma PreRunner, black, extended cab, 2wd step side pickup, with the 5vz-fe engine, auto trans (not sure yet which tranny). It currently has 131, 300 miles. The body, other than the front bumper, is pretty straight, with a couple minor dents. The paint on the roof, hood, and top of the fenders is horrible- its spent it's life in CA, mostly in the sun, and the clear coat is gone on the roof, hood, and fenders. Also, the headlights are cloudy, and the hood has a rust spot where the paint has baked off the hood.
From the inspection when I bought it, there's some needs, with various priorities.
-paint, mentioned above
-headlight lens rehab/replacement
-Valve cover gaskets
-all 3 belts are cracking and will need replacing
-Plugs/wires
-rear shocks (they're pretty bad)
-front struts (they're totally shot)
-front bumper (it had a minor encounter with a fawn deer and is slightly bent); am considering a PreRunner style tube bumper
-transmission: while cruise control is on, shifts hard from 3rd to 5th (I think) when up steep hills with rpms around 3500. Not sure if it's fluid related or what.
-Front upper and lower control arms/A arm bushings need replacement
-ball joints in front are notorious for failure
-it has aftermarket wheels 15"x 12" ( I think) with 31" tires, but needs a narrower, or more backspaced wheel, since it rubs at full lock turning
-exhaust needs work- it has headers and cat intact, however, it's been chopped just after the cat, right behind the cab. I'd like high-flow exhaust that won't trip the O2 sensors.
-it needs a trailer hitch. And possibly an auxiliary tranny cooler for mild towing and road trips.
Goals for the truck:
-I have an FJ80 parts rig I am thinking of using the axles, tranny and Tcase to convert it to 4x4, since it's already on a 4x4 chassis.
-I want to do minor towing with it (firewood, camper, hardware store/town runs, etc).
-considering a leveling kit for the front until I can do an axle swap, since I already need to replace the struts
-keep it cheap!!! But reliable!
So, are there any vendors recommended in the Tacoma realm (I'm usually on the FJ80 forum) that deal with suspension, bushings, exhaust, etc? Any suspension suggestions for towing and hauling ? Any info on transmission coolers to add? Any other PreRunner owners out there willing to post up their rigs so I can get some build ideas? Any other info, especially regarding SAS conversion, would be great. I've already searched, and only come up with eBay listings.
-Plugs/wires
